The HD 8500m is the dedicated GPU it should already be using it when running more graphically intensive programs and apps.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1197586-help-me-choose-a-gpu/#findComment-13625375
Depends on the laptop, usually there is an option in bios to use one or the other or have them switch depending on the task.
More often than not this is done through the drivers and recently windows 10 has an option that let's you select the programs and games you want to run the better graphics card on so that you will save power on lesser demanding tasks like browsing the web.
https://linustechtips.com/topic/1197586-help-me-choose-a-gpu/#findComment-13625409
