Budget (including currency): $1500
Country: United States
Games, programs or workloads that it will be used for: Adobe Premiere Pro, Sibelius, Heroes of Newerth, Star Wars Jedi: Fallen Order, etc. Some gaming, some general workflow.
I'm including the PC Part Picker list. Are there any issues I might run into here? I'm planning to have dual monitors with the basic dell being used in portrait mode for workflow things. Do I have enough power? Any compatability issues that PC part picker is not telling me?
https://linustechtips.com/topic/1197157-first-build-please-help-if-possible/
The list is fine, but are you really gonna spend 550$ for a monitor? That's more than you CPU+GPU budget.. And your GPU isn't gonna keep up with 144 FPS anyway in most cases unless you reduce settings quite a lot or you just play MOBA level games.
Parts are fine but I hope you're not actually paying that for the monitor. It's more than twice what it should be.
In most games it'll go well over 100 fps. You don't need to hit 144hz to make the monitor worth it, and you certainly don't have to play at max settings.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
That's really personal choice. I'd never buy a monitor worth more than half system, and I'd always go quality over FPS. Maybe he does too, that's why I'm asking him.
It's not the fact that it's $550, it's the fact it's MSRP is $249.
At that price point get an MSI B450 Tomahawk MAX. The Asus B450 boards are terrible.
