I would like to run a length of Ethernet cable from my router (down stairs) to my bed room (up stairs) i am thinking of getting a 5m Ethernet cable to do this as it is just going straight up and thru the floor what would be the best cable type to get for this?
thanks Merc
https://linustechtips.com/topic/1196796-ethernet-cable/
Any.  5m is an inconsequential length for Cat5 or Cat6.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1196796-ethernet-cable/#findComment-13619205
14 minutes ago, Mamonos said:
Assuming you are still on Gb,i f you want it future proof you should get CAT6, CAT6A or even CAT7 cable so you are set up also for 10Gb Ethernet (CAT6 will be enough for 10Gb at that lenght).
Cat 7 is pretty much pointless for most networks. The vast majority of "Cat 7" cables don't even use connectors that meet the requirements of the Cat 7 ISO standard (GG45 or TERA).
Stick to Cat 6a as you're more likely to get a cable that actually meets the standard rather than whatever cable someone is marketing as Cat 7, which isn't even recognised by TIA as a standard.
https://linustechtips.com/topic/1196796-ethernet-cable/#findComment-13619253
thanks Merc
Techincally speaking Cat5e and Cat6 will carry a 1Gbps signal up to 100m. Cat6 will do 10 Gbps under shorter distances and Cat6a will do 10Gbps up to 100m. Honestly Id probably do Cat6 as its a better standard than Cat5e and should be cheaper than cat6a as well as probably would be able to do 10 Gbps if you needed.
Stay away from CCA (coper clad aluminum) cabling. Its generally consider low grade.
https://linustechtips.com/topic/1196796-ethernet-cable/#findComment-13620973
