HElp
Go to solution Solved by minibois,
2 minutes ago, frenzen said:
My god that sounds so simple. I will do that since I have bootcamp
It really is that simple too ¯\_(ツ)_/¯
But I guess that's just because the Windows media installer is not compatible with MacOS. Just like how you can't make a MacOS installer from Windows.
3 minutes ago, frenzen said:
I have GA-A320M-S2H motherboard, I have installed everything as I connected 24 pins, 8 pins and sata pin and since I havent gotten my case when I touch +PW- with my screw driver, nothing happens or boots up.
Can you list your full system specs?
What do you mean with 'nothing happens' exactly? No LEDs, fans, etc.?
Try using another metal object to short the pins, just to be sure.
https://linustechtips.com/topic/1196459-help/#findComment-13616791
Oh it was a noob mistake and I didnt turn on the PSU, however I have another problem, the fan starts spinning I have power but it says there is no signal.
This is my built except it has ZOTAC GeForce GT 710 1GB DDR3
https://linustechtips.com/topic/1196459-help/#findComment-13616910
Do you have your monitor plugged into your videocard? Does your videocard have power?
If you are not using a videocard, are you using a CPU with integrated graphics?
Getting your full system spec list would still be helpful if you are still having issues after double-checking the questions above.
https://linustechtips.com/topic/1196459-help/#findComment-13616917
I posted my full spec ^ in that post
https://linustechtips.com/topic/1196459-help/#findComment-13616918
This CPU does not have integrated graphics, you need a videocard in the system to get video out.
nvm, didn't saw you were usingthe GT 710. Your monitor is plugged into that, right?
https://linustechtips.com/topic/1196459-help/#findComment-13616920
It worked plugging into videocard, it didn't before
https://linustechtips.com/topic/1196459-help/#findComment-13616922
reboot and select proper boot device or insert boot media in selected boot device and press a key. when I press a key it keeps sends me the message
https://linustechtips.com/topic/1196459-help/#findComment-13616929
Turn off the machine, turn on the machine and immediately start pressing the DELETE key. That should bring you into the BIOS.
Do you have a USB drive with the Windows installation handy already? Make sure that is set as the first drive to boot from and then install Windows
https://linustechtips.com/topic/1196459-help/#findComment-13616933
How do I set that as the first drive to boot from?
https://linustechtips.com/topic/1196459-help/#findComment-13616945
https://linustechtips.com/topic/1196459-help/#findComment-13616971
Also what else do i need to do in bios?
Turn on XMP here:
That makes it so your memory is running at the full speed.
https://linustechtips.com/topic/1196459-help/#findComment-13616984
11 minutes ago, frenzen said:
I put it as default usb with windows and save and exit, but nothing appears
What is 'nothing'?
Is the system turned off, fans spinning, output on the screen, etc.
https://linustechtips.com/topic/1196459-help/#findComment-13617031
As if like the screen is black and keeps showing this "-", I booted my usb using this tutorial. The fans spin and everything
I'm not sure how well this video's contents would work.. But I do see this comment:
Quote
If this doesn't work I'm gonna end up installing windows on my mac to install windows on my pc lol
Update: I had to do exactly that
So that does not make me hopeful.
https://linustechtips.com/topic/1196459-help/#findComment-13617048
What is the best tutorial how to make a bootable windows 10 on windows?
https://www.microsoft.com/en-us/software-download/windows10
Download the program, say you want to create a bootable media stick, choose the stick, wait a bit and you're done.
Now just boot from the stick and you can install Windows
https://linustechtips.com/topic/1196459-help/#findComment-13617064
https://linustechtips.com/topic/1196459-help/#findComment-13617066
https://linustechtips.com/topic/1196459-help/#findComment-13617077
I’m actually going to use Rufus using GPT UEFI (non CSM) and NFTS, hopefully that works. Some say to try fat32 instead of NFTS
https://linustechtips.com/topic/1196459-help/#findComment-13617110
