So I have a budget of $1200...Here is what I've got. Tell me if you have any suggestions.
CPU:  Intel Core i5-4440 3.1GHz Quad-Core Processor  ($214.00 @ CPL Online)
Motherboard:  Gigabyte GA-H87-D3H ATX LGA1150 Motherboard  ($128.00 @ CPL Online)
Memory:  GeIL DRAGON 8GB (1 x 8GB) DDR3-1600 Memory  ($89.00 @ Mwave Australia)
Video Card:  Gigabyte Radeon R9 280X 3GB Video Card  ($399.00 @ PCCaseGear)
Case:  Thermaltake Chaser A31 ATX Mid Tower Case  ($103.00 @ CPL Online)
Power Supply:  XFX 550W 80+ Bronze Certified ATX Power Supply  ($84.00 @ PLE Computers)
Operating System:  Microsoft Windows 8.1 (OEM) (64-bit)  ($115.00 @ CPL Online)
Total: $1201.00
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-24 00:01 EST+1100)
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/119623-1200-aud-max-gaming-pc/
Suggestions:
  • A CPU cooler.
CORSAIR RIPPER: AMD 3970X - 3080TI & 2080TI - 64GB Ram - 2.5TB NVME SSD's - 35" G-Sync 120hz 1440P
MFB (Mining/Folding/Boinc): AMD 1600 - 3080 & 1080Ti - 16GB Ram - 240GB SSD
Dell OPTIPLEX:  Intel i5 6500 - 8GB Ram - 256GB SSD
PC & CONSOLE GAMER
https://linustechtips.com/topic/119623-1200-aud-max-gaming-pc/#findComment-1594339
8.1!?! NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
I'm not a fan of the mobo, but its great for the price. Really great!
"When one person suffers from a delusion it is called insanity; when many people suffer from a delusion it is called religion." - Robert Pirsig
https://linustechtips.com/topic/119623-1200-aud-max-gaming-pc/#findComment-1594342
or you could get a $515 gpu. just saying.
(if u dont catch on from that much info then you probs shouldn't do it anyways)
In the grim darkness of the far future, there is only a GTX 1080, just a single 1080, where my glorious PC once stood....
For that is all I need, For the Emperor of Man, Jen-Hsun Huang, protects. We march for Nvidia, and we shall know no fear!
https://linustechtips.com/topic/119623-1200-aud-max-gaming-pc/#findComment-1594343
shut up.
https://linustechtips.com/topic/119623-1200-aud-max-gaming-pc/#findComment-1594363
Just a fun AMD build
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($194.00 @ CPL Online)
CPU Cooler:  Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler  ($59.00 @ PCCaseGear)
Motherboard:  Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard  ($89.00 @ Mwave Australia)
Video Card:  XFX Radeon R9 280X 3GB Video Card  ($379.00 @ PCCaseGear)
Case:  Silverstone TJ08B-E MicroATX Mini Tower Case  ($99.00 @ PCCaseGear)
Total: $1177.00
(Generated by PCPartPicker 2014-02-24 00:27 EST+1100)
https://linustechtips.com/topic/119623-1200-aud-max-gaming-pc/#findComment-1594405
Go for a 2x4gb memory kit and save some cash, maybe cut back on case and a few things to try and squeeze a better nvidia card in
  • Cooler Master Storm Enforcer
  • I7 3770K @ Stock
  • Gigabyte Z77X-UD5H
  • AMD Radeon R9 290
  • Cooler Master Hyper 212+
  • 16gb Corsair Vengeance 1600mhz
  • 2x 1tb WD Green Drives (RAID 1)
  • 256gb Samsung 840
  • Peripherals
  • Logitech G502 Proteus Core
  • Ducky Shine 3 - Blue LED, Brown Switches
  • Samsung SyncMaster 2443
  • Custom Mousepad http://imgur.com/xJWASQM
  • Logitech G35
  • Altec Lansing Octane 7
https://linustechtips.com/topic/119623-1200-aud-max-gaming-pc/#findComment-1594449
Might i recommend Scorptec, cheapest postage and its all express too! trust me, if its got to be mailed, they'll be your cheapest, more expensive per component, but shipping is dirt cheap making total cost less!
And you don't want the gigabyte 280x, doesn't overclock to save its life, your lucky to get anything more then a 50mhz OC (only the rev1-1.2 7970 could OC and the 280x is a rev2.0 7970)
I've got a gigabyte WF rev2 7970 and a PowerColor 280x in my system, and the Powercolor is the much stronger card, plus comes with a really nice cooler and a backplate. really adds to the premium feel at a really really good price.
http://www.mwave.com.au/product/powercolor-amd-radeon-r9-280x-turboduo-overclock-3gb-video-card-ab53498 $369 (sorry about the no stock, my bad bought their last one ;) )
and using that extra $30 bucks you could get a Cougar CMX700W,
http://www.mwave.com.au/product/cougar-cmx-700w-80plus-bronze-modular-power-supply-ab49037  $99
Its semi Modular with flat cables (godsend for those not sleeving) and stable, runs crossfire eyefinity with a heavy OC on the CPU, and two 7970's/280x's at 1075/1450.
gives you room to impove with a second 280x in 8-10 months if you decide you're sick of sitting on the 55-65 FPS on max with 4xaa forcing you to use terrible vsync ;)
550 is enough, but its nice having headroom and the ability to expand later.
Plus with those two changes alone you're now actually under 1200 and your rig is now more open to future upgrades ;)
Mobo http://www.pccasegear.com/index.php?main_page=product_info&products_id=23623&cPath=1491 $105
You really can't go wrong with matx or an asrock in a budget build, asrock are actually really good unless you're looking to squeeze every mhz when OCing.
so that gives you about an extra $30 to do what you like with, 45 if you stick with your PSU, then a nice CPU cooler
http://www.mwave.com.au/product/cooler-master-hyper-212-evo-cpu-cooler-aa16704 $ 39
and you've saved $6 for the whole build, and got a cooler, or have stuck with the stock cooler, have $30 saved and have the ability to upgrade later.
or you could do all the upgrades, and have only spent an extra $15 bucks, bigger PSU, equivalent GPU and Mobo and plenty of options for in 6 months when you're feeling the strain of whats effectively a 3 year card design now.
I must be feeling sick, I'm actually thinking budget properly, with my setups, i set a budget, then i pick the parts i want, and end up spending a lot more then my budget said:P
might save this list but, would be a good secondary build, gives me ideas :P
Rig 1 CPU: 3570K Motherboard: V Gene GPU: Power Color r9 280x at 1.35GHZ  RAM: 16 GB 1600mhz PSU: Cougar CMX 700W Storage: 1x Plexor M5S 256GB 1x 1TB HDD 1x 3TB GREEN HDD Case: Coolermaster HAFXB Cooling: Intel Watercooler
"My day so far, I've fixed 4 computers and caught a dog. Australian Tech Industry is weird."
"It's bent so far to the right, It's a hook."
https://linustechtips.com/topic/119623-1200-aud-max-gaming-pc/#findComment-1594510
