recently everytime i open up a game and play for a few minutes the screen turns black or white and disconnects from my monitor. this also happens when i open up other things like google. i also noticed my pc was a little slower and had lower fps in games. im not sure wether its my ram or power supply. my specs are ryzen 7 2700, asrock rx 580, 16 gb ddr4 2400, and asrock b450m/ac.
https://linustechtips.com/topic/1196049-help/
11 minutes ago, v1tr01l1c said:
Yeah the screen says no signal and ive tried different cables.
 I assume at this point you have already reseatedyour GPU as well as the power cables.
To me this still is consistent with the gpu drivers. I would recommend using something like Display Driver Uninstaller to remove your current drivers and then you can reinstall them again.
https://linustechtips.com/topic/1196049-help/#findComment-13613805
when the screen turns to black, is the pc restarted or not? if not, i think your psu is fine. try to run cinebench with both your internal and discrete gpu
A8 7650K@stock | Hi-Fi A70U3P FM2+ Biostar | 2*4GB DDR3 @2133MHz Team Dark | GTX 1050 OC 3GB Gigabyte | 500GB 7200rpm Seagate Baracuda | 450W 80+ Super Flower | 22" BenQ
https://linustechtips.com/topic/1196049-help/#findComment-13614092
everytime i boot up my pc a few moments later the screen turns white and freezes so i have to shut down my pc
https://linustechtips.com/topic/1196049-help/#findComment-13614319
1. go to save mode. if it went well and no white/black screen happened, it might be a driver issue or virus. try to ddu your discrete gpu driver on save mode, and scan with any updated antivirus available. after ddu and with no driver installed, try again to boot in windows just to make sure its a driver related issue.
2. if its still happened, maybe there's overheat issue with your gpu / monitor
https://linustechtips.com/topic/1196049-help/#findComment-13614352
when i boot into safe mode it doesnt connect to the internet?
https://linustechtips.com/topic/1196049-help/#findComment-13616135
there are usually two different safe modes for windows. safe mode and safe mode with networking.
You can usually access either of them by pressing f on your keyboard while booting (could be different per motherboard manufacturer)
But internet will be working outside of safe mode nevertheless, we are just going into safe mode to delete the graphics drivers then returning to normal windows to do the reinstall
https://linustechtips.com/topic/1196049-help/#findComment-13616179
I went into safe mode with networking and it still doesn’t connect to the internet for some reason
https://linustechtips.com/topic/1196049-help/#findComment-13617634
doesn't matter if you have internet connection or not
you can download ddu on normal windows before safe mode or download it on your phone (or wherever) than copy it to your pc on safe mode
than do ddu when safe mode. i dont think ddu needs internet connection
and also, is your gpu fan turned on? can you check the temp on bios?
https://linustechtips.com/topic/1196049-help/#findComment-13621455
