Where do I connect these too?
Solved by DildorTheDecent,
3 minutes ago, Jakob11 said:The 3 and 4 pin ones are from the Rog ryuo 240.
Male fan connector. You'll see similar connectors on your motherboard. You can choose to either run the fans from the cooler, or from the motherboard.
Female RGB connector. This connects to your motherboards RGB connector (if present). Make sure that voltage matches on the board and the cooler. Voltage is usually 5V or 12V.
Usually the gender is omitted. And they're probably both under the wider Molex family as it is a brand name. But we'll keep things simple for now.
