Hi
I want to buy AIO cooler for my 3800x CPU for silent system and because my case raidmax zeta has no place for bulky air cooler also I wont OC. So I found some brands most of them are expensive from Aorus, Asus, Tt but I found one from brand called gamedias with 2 and 3 fans and good price. I tried to search for any review for this brand but did not find any, did any one tried this brand ? should I get the 2 or the 3 fans model ?
Model name is Gamdias Chione
https://linustechtips.com/topic/1194973-aio-cooler/
4 minutes ago, Coolday said:
Hi
What country are you shopping from and what is your budget, this is not that good of an AIO cooler, although if you must select it then I would go for the 3 fan version?
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/1194973-aio-cooler/#findComment-13605685
2 minutes ago, Coolday said:
I dont want to say about my country. I just dont want to get high end one as I wont oc my cpu.
They want to know where you're from so they know what options you have available to you.  No need to be paranoid unless you live in a country where you being on the internet is forbidden and you worry we will turn you in.
The Liquid Freezer II by Artic is cheaper.  The Fractal Design S36 Celsius is cheaper.  The EVGA CLC 280 is cheaper.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1194973-aio-cooler/#findComment-13605718
Dont have the Arctic I have these options:
DEEPCOOL GAMMAXX L240 V2
DEEPCOOL GAMMAXX L360 V2
DEEP COOL CASTLE 240 RGB V2
DEEPCOOL Gammaxx L120 RGB
GAMDIAS CHIONE P1A-360R
GAMDIAS CHIONE E1A
Cooler Master ML 240R ARGB
GAMDIAS CHIONE P2 360R
Thermaltake Water 3.0 240 ARGB Sync Edition
THERMALTAKE fan Water 3.0 Riing RGB 360
THERMALTAKE fan Water 3.0 ARGB 120
Thermaltake Water 3.0 360 ARGB Sync All-in-one 360mm
XPG LEVANTE CPU Cooler
Cooler Master MasterLiquid ML240 RGB
GAMDIAS CHIONE M2 240R RGB
GAMDIAS CHIONE E2 120R RGB
COOLERMASTER MASTERLIQUID ML240R RGB CPU COOLER
Gamdias Case Fan Cooling CHIONE E2-120R
MasterLiquid ML240L RGB
https://linustechtips.com/topic/1194973-aio-cooler/#findComment-13605725
GAMDIAS CHIONE E1A
You gonna tell us what the prices are?
https://linustechtips.com/topic/1194973-aio-cooler/#findComment-13605737
That's okay if you don't want to include what country you are shopping in, I understand, although unfortunately I won't be able to help you with part suggestions that are likely to be found in the specific country you are buying from.
The Raidmax Zeta case has support for upto 280mm or 360mm radiators which is great, I would get an EVGA CLC 360 liquid cooler if that is available or my second recommendation would be Cooler Master's MasterLiquid ML240L RGB.
        @Boomwebsearch
https://linustechtips.com/topic/1194973-aio-cooler/#findComment-13605741
1 minute ago, Coolday said:
I selected the ones I can pay for dont worry about prices.
Get this one:
That's based off of this chart from this site:
https://www.eteknix.com/deepcool-gammaxx-l240-v2-aio-liquid-cooler-review/5/
https://linustechtips.com/topic/1194973-aio-cooler/#findComment-13605746
GAMDIAS CHIONE E1A
ThermalTake Water performs very well per Gamers Nexus testing and my own personal use.
It's silly to not tell people your budget or country you'll be buying from, so without the price/performance metric we just have performance.  Also since you won't be OCing... literally any AIO is fine for the 3800X.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1194973-aio-cooler/#findComment-13605750
