Suggestions for CPU cooler,case cooling and case fans;
hussain_mdj
I have a Ryzen 5 1600 paired with RX570. I plan to overclock my processor to 4ghz. What cooler would you guys suggest? My budget is upto 70$. Can Hyper 212 evo cool my processor?
Now about the case case fans..I have a Cooler Master MB511. The front panel can fit 3x120mm fans OR 2x140mm. Which ones should i go with? The top panel can be mounted with 2x120mm or 2x140mm so for the top i'm gonna go with 2x140mm...but what about front panel..? Which one's gonna provide better cooling (3x120mm or 2x140mm)?
About case fans would you guys suggest Ring LED fans or normal RGB fans [Fan which blades glow] for better look? I'm also open to all case fans suggestions.
If you guys can't understand the above here are my questions
  1. Best CPU cooler for Ryzen 5 1600 under 70$
  2. 3x120mm or 2x140mm front panel case fans for intake
  3. Ring LED case fans or Normal ones[Fans which blades glow] for better look/brightness/glow in case
  4. RGB budget case fans suggestions [RED]
Buy the RGB fans from ebay or aliexpress
3 120mm fans in the front is plenty, don't even really need exhaust fans at that point.
The Scythe Fuma 2 or Neptwin would be the cheapest dual tower coolers, get a Dark Rock Pro 4/Noctua D15(AM4) otherwise.
might as well go a bit overkill since you'll have the cooler for years
bequiet! Dark Rock pro 4 should fit your budget for the CPU. The Hyper 212 will do its job also. You can go with it if you wanna save money.
I would go with 2x140 Intake. One part less that needs to be replaced at some point.
And at least 1x120 in the Back as outtake. One above the cpu as outtake as well.
Here my Rig that may give you an Idea.
Btw. Blue LED Fans reduce tthe Heat by another 5%.
5709b7eb0e339_20150708_204919(800x450).jpg.40bd23dff9525a07d38f10b478acea65.thumb.jpg.1635060a3dc3186425e33ca46531cef3.jpg
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
Got it..!! But the problem about good quailty coolers is I live in India and the dark pro4/noctua d15 cost upto 100$ here :( ...and i just found out NEPTWIN costs around 52$ i think i'm gonna go with it.Thank man
Thank man...build looks OP🔥
The neptwin should come with an AM4 bracket at this point, may need to contact the company if it doesn't.
