Hello i need some help cause im not sure what happend suddenly to my pc earlier it was fast no problem with it fast boot and fast to do things.
I got home 1hour ago tried to start it and it took 10-15 min to just get on windows it took around 20-25 min to also get the pc to load up the programs and we are talking about maybe 2 programs here bir defender and logitech g hub thats it
im really not sure what have happend and would like to ask you all if maybe some of you would think what it could be i was thinking it maybe was my hard drive something was wrong with but offcause im not sure
it should also be said i just change gpu cpu motherboard cpu fan and ram like 2-3 month ago
my whole system is
ryzen 5 3600
16 gb of ram
3 tb hard drive
256gb ssd
550 watt power supply
https://linustechtips.com/topic/1193829-help-with-pc-getting-slow-suddenly/
What model is the 128GB SSD? Have you checked your drives with CrystalDiskInfo from https://crystalmark.info/en/software/crystaldiskinfo/?
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
28 minutes ago, shadowss said:
nope havent checked them i have pcmark 8 i could check them with and im not really sure which ssd it is and just saw it was a 256 gb ssd
PCMark 8 does not tell you S.M.A.R.T info on your drives. Try out CrystalDiskMark to check if your drive has bad sectors, it will also tell you your drive model.
Desktop
Homelab
Desktop
Homelab
1 minute ago, shadowss said:
it says its a ct250mx500ssd1 250gb and it says both are god 100% 40C on ssd and 38C on harddrive
It's a Crucial MX500, probably not the issue here then. Is your Windows installation on the SSD?
Desktop
Homelab
It could be multiple copies of virus software.
What antiviral are you running?
Do you understand how to use task master to see what is actually running on the machine?
Have you installed or updated anything in the last few days?
Has windows updated in the last few days?
Is the system running hotter?
  • 1 month later...
