AIO and fan positioning
Go to solution Solved by SolarNova,
Push/pull wont help much. its only really helpful with thick rads.
Just run 3 intake at front.
1 exhaust on rad at the back.
That will certainly give u positive pressure and reduce dust.
If u find ur case is retaining to much heat from the GPU u can always move one of the fans to the top as exhaust.
I'm running a ryzen 5 2600 stock and a 1060 6gb.
The case is a Cooler Master MasterBox K500L and the AIO is a Cooler Master MasterLiquid Lite 120.
I have 4 fans in the case, two 120mm ones at the flront (with red LED), 1 in the back (2000rpm) and one the top part of the case(this one is the one that came with the IAO and only runs at 1000rpm).
I noticed my CPU heats a lot while doing heavy work it reaches 90+ºC at times.
I wnated to change the fan and AIO positoning but IDK what is the best possitioning for them.
I will leave a few photos of my case, if anyone could take a look and give a piece of advice I would much apreciate it.
P.S I know the case is filthy I'm gonna clean it tomorrow 😅
Thanks.
https://linustechtips.com/topic/1193827-aio-and-fan-positioning/
Tubing at the bottom idealy. stop air from being sucked up within the endtanks of the rads.
120mm AIO suck btw. Should have got a 240mm for that case, or an air cooler. either of them would cool better than a 120mm AIO.
That being said, i would stick that AIO at the back of the case where u have the rear 120mm. Set as exhaust.
Then have the 2 fans at the front as intake.
Dust ur case aswell :P   chances are ur suffering more dust than normal due to the 1in 2 out negative pressure ur running. Setup as above and ull be running positive pressure thus less dust buildup.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Dust ur case aswell >.<   chances are ur suffering more dust than normal due to the 1in 2 out negative pressure ur running. Setup as above and ull be running positive pressure thus less dust buildup.
That leaves me with one spare fan should I put it in the front of the case? Or should I have two exausting trough the AIO? (one pulling air into the AIO the other pulling it out the case)
