I am planning to sell my 7700t and its motherboard because the ram slot when faulty after i change my pc case. I ordered my 3700x and b450m mortar max yesterday. Now I am browsing forum to check on temperature of 3700x.
It seems like 3700x stock cooler can hold the cpu down to 85 C with PBO on? I am a bit paranoid when it comes to cpu temperature... previously my 7700t only ran max to 67 C with my cryorig H7. So I am seeking for solutions:
1. Just use stock cooler with stock thermal paste?
2. Use stock cooler but with cooler master mastergel maker (~ 5 usd solution)
3. Buy scythe mugen 5 rev b and cooler mastergel maker ( ~50usd solution).
Also I am tight on budget because originally my plan is to buy 3600 not 3700x. will the ~5-50 usd investment be worth it and will i see any performance gain? Thank you for your attention and time!
  • CPU
    Ryzen 7 3700x
  • Motherboard
    MSI B450M Mortar Max
  • RAM
    Klevv Bolt X 3600mhz CL18 overclocked to 3600mhz CL18 @ 1.35V. (latency 67 ns)
  • GPU
    Gigabyte Windforce GTX 1080
  • Case
    Fractal Design Define Mini C Windowed
  • Storage
    1TB HDD from Toshiba, 250 gb Samsung 850 evo, 2TB Western Digital SN750
  • PSU
    Superflower Eco Silver 600W
  • Display(s)
    Dell U2417H
  • Cooling
    Arctic freezer 34 esports duo, Arctic P12
https://linustechtips.com/topic/1193584-3700x-cooling-solution/
The ryzen chips tend to be in the high 70c range under load with a decent cooler. You have to keep in mind that Ryzen chips will automatically overclock themselves if there is thermal headroom.
I think you wouldn't really need anything over a hyper 212 unless you really wanted to push the chip.
https://linustechtips.com/topic/1193584-3700x-cooling-solution/#findComment-13595207
In my country hyper 212 costs same as scythe mugen 5 rev B.. does 212x has advantage over mugen 5?
  • CPU
    Ryzen 7 3700x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    Dell U2417H
  • Cooling
https://linustechtips.com/topic/1193584-3700x-cooling-solution/#findComment-13595225
Not really, the 212 is just super cheap in the US. *The scythe is actually probably better. I haven't read reviews of it though.
https://linustechtips.com/topic/1193584-3700x-cooling-solution/#findComment-13595246
Thermal paste doesn't really give you real help. So using another paste vs stock isn't gonna do much. Also PBO target temp seems to be 80C (based on threads I've read). So keeping it enabled and changing cooler doesn't necessarily mean better temps. It just mean better performance.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1193584-3700x-cooling-solution/#findComment-13595818
I see, how big a performance boost will I see using other cooler? Is it like 4.0 ghz vs  4.4ghz all cores?
  • CPU
    Ryzen 7 3700x
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    Dell U2417H
  • Cooling
https://linustechtips.com/topic/1193584-3700x-cooling-solution/#findComment-13597774
There are no test like that. Here's explanation of PBO so you can see how big of difference it makes overall https://www.gamersnexus.net/guides/3491-explaining-precision-boost-overdrive-benchmarks-auto-oc
https://linustechtips.com/topic/1193584-3700x-cooling-solution/#findComment-13597800
