Sorry, I know this is long, but more  detailed information is better, right?
About three weeks ago i've built this rig and it runs pretty damn smooth, until about a week ago. Nothing really major, but whenever i turned on my pc, the cpu fan would spin loud with VGA light on mobo, no display and the "Gefore RTX" light would be off for about 7-15 seconds before turning on. Past that everything ran smoothly, but I didn't remember my GPU light not coming on when i booted everything up right away, so I figured maybe it had something to do with the connection cables since that was an issue before (not having them plugged in all the all or enough).
I made sure i had all the power cables connected properly again and booted it up again and while the GPU light wouldnt turn on right away, it was much more faster and consistent, so i decided that was okay and to not stress, especially since game performance was the same too.
So now, out of nowhere, my FPS is getting cut in half. Playing Warhammer 2 benchmarks onUltra gave me a 120 average FPS, now its at 65. It runs smoothly, temps are okay, but the FPS is much lower than it used to and I didn't do any changes to it. Yes, Vsync is off too. I put the in game FPS tracker in steam after i messed with the GPU cables and FPS was high then still, but not now. I've tried other games, but I can't say for sure if they've taken a hit too since I did had Vsyinc on with those, except for Warzone which i believe didn't take a hit at all. I've unistalled and Warhammer 2 and reinstalling it now to see if maybe that can fix anything, but I doubt it.
Is there anything I should be worried about? GPU bad? Mobo? CPU? Temps are fine across the board, i recently installed Corsair LL120 RBG fans... maybe too much stuff for my micro atx mobo? Only chance i've made in BIOS recently was setting fan speed. Please help, I spent so much on this PC to not be stressed out this hard from it lol
Specs:
RTX 2070 Super FE
Ryzen 3700x
Aorus B450 m mobo
Corsair 8 gig x2 LPX Vengence 3600
EVO 860 Samsung 500 Gig SSD
Inland NVME M.2 250 gig
Corsair CXM750 PSU
Specs:
RTX 2070 Super FE
Ryzen 3700x
Aorus B450 m mobo
Corsair CXM750 PSU
Did you try dduing the drivers and did you try and other game ?
Phone: Pixel 3a (Purple-ish).
Build Log:
Hey, going to DDU it right now. Other games i THINK they run fine? COD Warzone runs the same and same with Insurgency, but I can't tell if GTA 5 is running as well as it should has SLIGHT frame drops in certain areas I believe it shouldn't be (graphic on max). I tested Battlefield 5 and it's really choppy at Ultra RTX on, when i fell like it shouldn't be since thats kind of the whole thing about RTX 2070 Super, being able to handle a game like BF5 on ultra settings above 60 fps.
Ill let u you know how DDUing goes
7 hours ago, livelongvoyager said:
So DDUing didn’t work. I’ve only tried it out with CoD Warzone and Insurgency and they seem to be running fine/normal.
It could be just the game
This is very unlikely the reason but what api did you use in that game ?
Build Log:
No API, it’s a single player game. I’ve searched everywhere for a potential bug for that particular game that could cause FPS to drop so much....but nothing remotely close. Only thing else to concluded is faulty or dying hardware, right?
now I have no display at all, but no VGA light on Mobo.
What so all the sudden your pc doesn't display a picture ?
Build Log:
So no display was fixed, just normal issues with Display Ports and new GPUs i guess lol, but game is still lower frames. I guess i'm going to do a factory reset and see if it's maybe an update or something I don't know I downloaded thats causing the loss of performance for that particular game. It's really weird.
