I don't know if this is the right place to ask. honestly iv'e never left anything on any type of blog or forum before. i just got my first SSD drive. its a Samsung 860 EVO and im trying to figure out how to get windows 10 from my HDD to the new SSD. if anyone could shine some light that would be amazing! thank you!
https://linustechtips.com/topic/1193404-please-i-need-help/
What specifically do you mean, do you want to transfer all of your files and Windows from your HDD to the SSD or are you referring to the Windows still being activated if you were to install a fresh install on the SSD?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1193404-please-i-need-help/#findComment-13593811
I think OP wants to transfer his OS to the SSD, which would require some sort of OS cloning software if I am not mistaken. With the amount of hassle that can sometimes cause (in my experience), I would just end up doing a fresh install on the SSD.
CPU: Ryzen 7 5800X GPU: Sapphire Pulse RX 9070XT Motherboard: Asus ROG Strix X470-F RAM: Corsair 32GB Vengeance 3600Mhz PSU: Corsair RM850X White
Cooling: Corsair H115i RGB Storage: Samsung 970 Evo NVME (2TB) Case: NZXT H500i White
Keyboard: Corsair K70 Mechanical Mouse: Logitech Superlight 2
https://linustechtips.com/topic/1193404-please-i-need-help/#findComment-13593826
I'm trying to transfer everything over from the HDD to SSD. i was given these hard drive to help me start building a pc and now that ive upgraded everything else i just got an SSD and am trying to move OS and everything off that hard drive to SSD
https://linustechtips.com/topic/1193404-please-i-need-help/#findComment-13593828
Macrium Reflect usually does a good job.
F@H
GPD Win 2
https://linustechtips.com/topic/1193404-please-i-need-help/#findComment-13593839
You will need to use a cloning software such as Macrium Reflect or Aomei Partition Assistant. It is also best to do it in a portable OS such as Winpe. But Macrium Reflect is my go to, it's easy to use and generally doesn't have a problem as long as the HDD is good. If it has bad sectors or any sort of issues however it can be a real pain, and you may need to use a raw copy program, that does sector by sector.
https://linustechtips.com/topic/1193404-please-i-need-help/#findComment-13593840
Just now, Almighty_Big_Man said:
i tried Macrium Reflect. idk if i did something wrong in the process but i couldnt get it to boot windows. i even unplugged old harddrives and made sure it was set to boot from ssd.
Sometimes macrium reflect will need to run a boot fix on the drive before it will work. It should have a boot fix option in macrium but it is only available in a portable OS. You can also try doing the clone with Aomei, I usually use Aomei if Macrium doesn't work and it can usually get it done correctly and it doesn't need to have the boot fixed.
https://linustechtips.com/topic/1193404-please-i-need-help/#findComment-13593853
1 minute ago, Almighty_Big_Man said:
i was told these hard drive are really old... so it may not work?
Please remember to quote who you are trying to respond to so we know when you reply. If the drives are really old and have bad sectors and or errors then they may not work, it's usually best when upgrading a computer or building a new one to do a fresh install of Windows. You should try Aomei first and if it still doesn't work then do a fresh install on the SSD.
https://linustechtips.com/topic/1193404-please-i-need-help/#findComment-13593862
sorry ill reply i didn't notice it.
https://linustechtips.com/topic/1193404-please-i-need-help/#findComment-13593869
I'll try aomei. now one more question, how do i format the ssd lol ive used Macrium Reflect and cloned it just didnt work so now it has all that on it.
Again, please remember to use the quote feature so we can see when you respond. You can format it in a Windows installer or if you can still boot into the older HDD, you can use disk management or diskpart in CMD to format it.
https://linustechtips.com/topic/1193404-please-i-need-help/#findComment-13593870
ok! thank you for the help i really appreciate it!
https://linustechtips.com/topic/1193404-please-i-need-help/#findComment-13593874
No problem, let us know how it goes!
https://linustechtips.com/topic/1193404-please-i-need-help/#findComment-13593878
