5 minutes ago, Sorenson said:
I wanted to update my Asus x570i bios so I decided to use ez flash over the internet. My computer has been on for about 20 minutes now with no video output. Is this normal or did the update glitch?
I would never trust using the ez flash via internet, albeit its a nice feature on paper, if you lose connection at any point in the update you can risk a file corruption, and symptoms like exactly what you are experiencing. I could recommend trying a Crash Free BIOS 3 flashback which can be found in your user manual on page 3-28. you would need another computer and a USB drive with a BIOS file downloaded onto it, simply follow the directions in the manual and see if that gets you anywhere.
CPU: Ryzen 7 5800X GPU: Sapphire Pulse RX 9070XT Motherboard: Asus ROG Strix X470-F RAM: Corsair 32GB Vengeance 3600Mhz PSU: Corsair RM850X White
Cooling: Corsair H115i RGB Storage: Samsung 970 Evo NVME (2TB) Case: NZXT H500i White
Keyboard: Corsair K70 Mechanical Mouse: Logitech Superlight 2
thanks so much, i’ll give that a try.
