help!
Go to solution Solved by minibois,
2 minutes ago, TeachMeGamers said:
so im thinking of building a new pc and the one im using rn is a prebuilt, sometimes when im playing games or opening alot of chrome tabs on my pc there is a message that shows up that says "out of memory" is that just a ram issue? or is it something else i just want to know i have 2x4gb ddr4 ram 2666 mhz or 3000 mhz im not sure
It means you don't have enough RAM for why you're trying to do.
Consider getting 16GB for your next system.
https://linustechtips.com/topic/1193311-help/
https://linustechtips.com/topic/1193311-help/#findComment-13593154
PS: It sounds like you don't have much of a pagefile.  (If you don't know, the pagefile is something the OS reserves on your hard drive for when you run out of physical memory -- it'll use the pagefile space instead.  This is considerably slower, fyi, but at least you won't hit a brick wall of an error message).
If you don't want to see that error again and you have some free space on your system, you can increase the pagefile size.  Here's a brief demo of how to do it in Windows 10:
https://www.tomshardware.com/news/how-to-manage-virtual-memory-pagefile-windows-10,36929.html
#Muricaparrotgang
Folding@Home Stats | Current PC Loadout:
Small                        Bigger				Biggerer				Biggest
Fractal Design Focus G       NZXT H1				Lian LI O11 Dynamic XL			Fractal Design Meshify C
FX-8320                      Ryzen 3 3200G			Ryzen 5 3600				Ryzen 7 3700X
120mm AIO                    120mm AIO				Custom 280mm loop			Noctua NH-D15
A motherboard                ASRock B450 mobo			MSI x570 mobo				MSI x570 mobo
16gb DDR3                    16gb DDR4 @ 3200			16gb DDR4 @ 3200			16gb DDR4 @ 3600
a melange of HDDs/SSDs       WD 1tb m.2				WD 500gb m.2				WD 1tb m.2/2tb HDD
PNY GTX 1070 x2              GTX 1070				GTX 1070 FE				MSI RTX 2080 TI
some 650w PSU                650W SFX-L 80+ Gold		MSI RTX 2080 Super			EVGA SuperNova 750w 80+ GOLD
								Corsair RM850x 80+ GOLD
https://linustechtips.com/topic/1193311-help/#findComment-13593189
