Hi all I’m new to pc gaming and I have noticed my cpu isn’t boosting to 4.4 I’m only getting 4.250 in game. temps 60-65c
can someone please help.
CPU- 3700X STOCK COOLER
GPU- RTX 2070SUPER GAMING X TRIO
MOTHERBOARD- ASUS ROG X570-F
MEMORY- VENGEANCE RGB PRO BLACK 16GB (2X8GB) 3600 MHZ AMD RYZEN TUNED DDR4 MEMORY DUAL KIT
PSU- CORSAIR RM750x Modular ATX PSU
https://linustechtips.com/topic/1192176-ryzen-3700x-not-boosting/
You shouldn't need to use pbo to boost to 4.4. My 3700x doesnt ever hit 4.4 at stock settings, but it does usually hit 4.3 and some change, sometimes 4.39.
I have a friend  with a 3700x that always hits 4.4 at stock if hes gaming or doing anything remotely cpu intensive.
Not sure what your deal is. Tge stock cooler makes me a little suspicious but the temps seem fine. My cooler is a noctua d15s.
CPU: Ryzen 7 3700x,  MOBO: ASUS TUF X570 Gaming Pro wifi, CPU cooler: Noctua U12a RAM: Gskill Ripjaws V @3600mhz,  GPU: Asus Tuf RTX OC 3080 PSU: Seasonic Focus GX850 CASE: Lian Li Lancool 2 Mesh Storage: 500 GB Inland Premium M.2,  Sandisk Ultra Plus II 256 GB & 120 GB
46 minutes ago, ChArLiE B said:
Thanks for the reply I have updated my cpu chipset drivers. Also for PBO I’m confused there are two options for PBO in the bios AMD CBS AND AMD OVERLCLOCKING what one should I enable PBO on ?
my bios I haven’t updated
Update the BIOS - that's a must for any modern system.
4.4 is single core boost at low load...no idea why...haha...in game usually 4.25~4.3...mine can overclock to all core 4.4 at .14v with air-conditioning...
  • CPU
    AMD Ryzen™ 7 5800X 4.7Ghz
  • Motherboard
    MSI MEG X570 ACE
  • RAM
    G.SKILL Trident Z Royal Series 32GB (2 x 16GB) F4-3200C16D-32GTRS
  • GPU
    GeForce RTX™ 3060 EAGLE OC 12G (rev. 2.0)
  • Case
    Cooler Master MASTERBOX MB520 ARGB + Cooler Master MasterFan MF120R ARGB
  • Storage
    ADATA XPG SX8100 2TB PCIe Gen3x4 M.2 2280 SSD
    ADATA LEGEND 960 4TB PCIe Gen4x4 M.2 2280 SSD
    ADATA Ultimate SU800 2TB 2.5" SSD
    Crucial BX500 2TB 3D NAND SATA 2.5-inch SSD
    Toshiba X300 4TB 7200 RPM
    TOSHIBA MG06 (MG06ACA10TE) 10TB 3.5 Inch 7200RPM Enterprise SATA Hard Drive
  • PSU
    Cooler Master MWE GOLD 750 FULL MODULAR
  • Display(s)
    Acer KG271B Gaming Monitor (HDR Ready 27" 1920X1080 240Hz)
    MSI PRO MP241
  • Cooling
    Cooler Master MASTERLIQUID ML240R RGB
  • Keyboard
    MSI Vigor GK80 RED GAMING KEYBOARD
  • Mouse
    Razer Naga Hex Wraith Red Edition Wired Laser Mouse
  • Operating System
    Windows 11 Home
  • Router
    tp-link EB810v BE22000 Tri-Band Wi-Fi 7 VoIP Router
    Asus ROG Rapture GT-AX 11000
  • Network Card
    tp-link Archer TBE550E BE9300 Wi-Fi 7 Bluetooth 5.4 PCIe Adapter
