Hey,
i just finished building my first PC yesterday.
Now i noticed some strangely high and impossible Numbers when checking temps and fan speeds with different programs, some Fans show RPMs up to over 50000 RPM and one CPU Temp Parameter shows -3 degrees Celsius, The CPU Fans are showing over 4000 RPM which isnt possible too, max. is 1700rpm. Is there something to worry about with the Temps and wrong Fan Speeds or is it okay? otherwise the build runs just fine.
attached is a txt file which i saved from OpenHardwareMonitor.
Specs:
Case: Corsair 275R Airflow
Mobo: MSI Gaming Plus Z390
CPU: i9-9900K with Corsair H100x Watercooling with 2x Noctua NF-P12 Fans
RAM: Crucial Ballistix LT Sport 4x 8GB
GPU: Gigabyte RTX 2080 Ti Gaming OC
PSU: Seasonic Focus PX-850
Fans: 4x Corsair AF120 White LED Case Fans
SSD / HDD: Crucial P1 1TB / 2TB Seagate Barracuda 7200rpm
OpenHardwareMonitor.Report.txt
https://linustechtips.com/topic/1192012-temps-and-fan-speeds/
I don’t download unmarked stuff off the internet  and the missing data seems to be possibly there so I can’t comment.
https://linustechtips.com/topic/1192012-temps-and-fan-speeds/#findComment-13583645
