Does Ram need cooling?
Solved by Senzelian,
Don't worry, your RAM will be fine.
RAM only needs a tiny bit of air circulation, which is already achieved by it heating up the air around it, which then begins to move upwards and the heatspreaders are designed to even out temperature differences between the individual memory chiplets.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
