Hi guys, hopefully i could get my answers to my pc problem.
My pc suddenly restarts everytime i play, it turns black screen for 5 to 30seconds then restarts the pc completely. at first i have CORSAIR VS650 power supply then as i am surfing through web for answers. some say that my PSU is not that good. so then i bought SEASONIC FOCUS GOLD 850W. i thought it should fix my problem, but then when i play and stream my pc didn't restart for 9 hours while playing COD and STREAMING. but then the problem came back without doing anything to my pc.
PS:
TRIED DDU AND INSTALL UPDATED DRIVERS
TRIED FORMATTING MY PC
*PC SPECS*
CPU: Ryzen 5 3600 3.6ghz
COOLER: Corsair h100i Platinum 240mm
RAM: Corsair vengance pro 3200mhz
MOBO: Aorus B450 M
GPU: Gigabyte rx 5600 xt gaming oc 6gb
PSU: seasonic focus gold 850W
FANS: 5x Corsair LL120 RGB fans
OS: Windows 10 Pro
MONITOR: MSI G24C4 24" 144hz (DISPLAY PORT)
2ND MONITOR: Nvision 22" 75hz (HDMI)
KEYBOARD: Corsair Strafe Mk.2
MOUSE: Corsair Glaive Pro
HEADSET: Corsair Void Pro
CAMERA: Logitech C920
IM DESPERATE. CAN'T AFFORD BUYING ANYTHING :(
https://linustechtips.com/topic/1190653-pc-problem/
Did you reinstall OS? I think it might be crashing.
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13573535
PS:
*PC SPECS*
MOBO: Aorus B450 M
OS: Windows 10 Pro
So try finding the broken part: If you have a second pc swap the parts and stuff. If you dont try running from the intagreated graphics (outputs on mobo) and try if thats working. Try if ur system has the same problem with Some sticks tooken out (i doubt that this would help anything tho )
Any Help is appricated! Please correct me if I´m wrong!
Sorry for grammer/spelling mistakes, but english is not my native language
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13573570
Things we need to know/Id try
What are your temperatures during gameplay?
What does Windows Event Viewer say?
Do you have MSI Afterburner/Riva Statistics Tuner installed?  (Uninstall them, from the bowels of reddit this has helped me before with a similar issue)
Any overclocks?  Turn them off - does issue persist?  (XMP is an Overclock btw)
Ensure XMP is turned off in BIOS - does this issue persist?  (XMP may be referred to as DOCP on your motherboard, not sure)
Is your Graphics card sagging to the point its potentially bending the PCIe slot on the motherboard?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13573629
I think it would be good to check event viewer if W10 has one,and report back error code here.
Sounds like overheating issue,I'd check cables,RAM for errors and first thing that came to my mind,bad gpu drivers...
This is a bit complicated to solve here on forum,might as well be motherboard failure.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13573715
PS:
*PC SPECS*
MOBO: Aorus B450 M
OS: Windows 10 Pro
Do you get BSOD before reboot?
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13573718
usually, the temperature is between 50 - 65 degrees, saw them while using MSI AFTERBURNER
when it restarts, it doesn't say anything. after the black screen and restart. it will just bring me back to lockscreen. i don't know that Windows event viewer as i am not good with pc.
i don't have any overclocks. XMP is off as well. i didn't touch anything in BIOS
i dont think my graphics card is sagging. i screw them well and the videocard is looking straight.
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13573925
i have fully airconditioned room. i don't think it is overheating because when i check the temperature in MSI AFTERBURNER it is only between 50 - 65 :/
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13573941
14 minutes ago, M A R K O said:
i did not, i only use the windows 10 recovery.
Do you have a Win 10 ISO to install Windows, or did you take the Operating System drive from a different PC and migrate it over to the new system?
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574010
though i built this pc, my friend has a USB with windows 10 pro in it. he is one of a technician in a computer shop. he helped me installing the OS of this. before i have nvidia 1050ti. i don't have any problem with it. then i used DDU to uninstall all drivers. and bought this Gigabyte rx 5600 xt gaming oc. now i have problems
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574046
So fresh install of Win 10 with GTX 1050 ti, you DDU'd and put in a RX 5600XT downloaded fresh drivers and started having issues - is that correct?
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574062
1 minute ago, M A R K O said:
Yes :( is it because of my GPU?
For myself, I would try DDU one more time (and do it with Safe Mode and all that crap that it recommends) and then reinstall drivers again for the RX 5600 Xt and see what happens
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574080
actually i did do reformat several times in windows 10. used DDU several times. it's still the same :(
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574087
Before RMA'ing the GPU as defective, Id have your friend reinstall windows from his thumb drive fresh and see if that clears up this issue (if its a software issue, it will.  If it doesn't, the card is likely defective)
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574147
alright, thats my last fix before i'll go to computer shop again to check this :/ someone replied on my other post in community.amd.com that sudden restart is because of MOTHERBOARD. because if its black screen only, blue screen thats because of GPU. but sudden restart is it is because of MOTHERBOARD failing. :/ i guess i can still afford buying new MOTHERBOARD but another GPU it is expensive. i am still a student
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574168
I wouldn't take their advice based on what you just typed.  There are a plethora of reasons things happen with PCs lol.
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574174
yeah, this is my first time building pc and i learned building pc through watching LTT's videos. didn't expect buying this GPU will cause me problems :/ anyways thank you for your help. i'll try installing fresh OS and see if problems still occur.
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574189
That would be my next step - after that if your system was stable before, tells me the card is the likely culprit - you can test this as well right now, without a fresh install - if you still have the 1050ti.  DDU out the RX drivers, put in 1050ti, install and see if problem persists.
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574207
yeah i still have the 1050ti right now. okay i will do it right now.
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574217
as i removed the gpu, i figured out that under the gpu is my m.2 ssd where my OS is installed. isn't it the crashing is the result of the m.2 getting too hot?
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13574284
SSDs don't mind running hot
BUT
How did the 1050ti swap go?
You could also troubleshoot that as an issue by either moving to another M.2 slot on the board that is compatible with your drive
https://linustechtips.com/topic/1190653-pc-problem/#findComment-13576738
