Budget: $1000-$1200
Country: California
Games, programs or workloads that it will be used for: Gaming, Light Editing
Other details: So I've never built my own PC before and I was wondering if my parts were good together and compatible? I'm trying to go for a budget build, but want high performance ( I know it seems like I'm an old cheapo, and that's because I am <3) I am very much a NOOB so I know some things but no were near as much as you probably know. I am slow on common computer knowledge but I am super open to learning terms and new computer info! Thanks yall for taking the time to read!
https://linustechtips.com/topic/1190227-first-pc-build-noob-help/
definitely you should be getting an XT 5700 best price to performance for that budget
NOTE: I AM NEVER ALWAYS RIGHT, BUT I AM HAPPY TO HELP ANYWAY I CAN
Tag me @WambleCropped or quote me so I can see your reply
My Rig: RTX 2060, R7 1700X, Samsung 860 500GB, Masterlite Liquid Cooler, Asrock Pro B540,16GB of RAM G.Skill 2133
PSU Tier List                    SSD Tier List                              Graphics Tier List
yup looks good just listen to other people not me
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
1 minute ago, adiack said:
@WambleCropped you have a rtx card why did you pick that i picked mine for the software feature
not gonna lie, Im kind of a sucker for ray tracing. I am also a big minecraft fan so....
1 minute ago, Louis562 said:
is RTX 2070s WINDOWFORCE OC 3x too powerful for my budget build?
its not that it is too powerful, its that the 5700 has better price to performance. Its cheaper and has very similar performance to the Super but is cheaper
Here's a PCPP list with some changes - should also be helpful if others want to quickly change components.
I included a bigger NVMe SSD and saved some money on the PSU - it's a decent PSU just like the MWE Gold, but semi-modular. You can save an additional 5-10 bucks if you go with a non-modular Corsair CX (2017). 5700XT would be my choice as well and yes the Gigabyte Gaming OC is a good card and comes with 3 fans.
