Need Help Choosing Between These Two
Solved by iBabySlapper,
Okay, I'll contribute my two cents, I'm gonna assume you're going for the 1st build.
- I'd just go with the cheapest X570 board you can find, with overclocking you're going to get very little from the 3900X, so I personally think it should just be run stock. VRM quality is a nice to have, but really isn't essential in any way. I would personally avoid Gigabyte boards, but that's a personal preference.
- I'd go for a 280mm AIO rather than a 360mm. While the 360mm AIO would have a minor edge in cooling performance, a 280mm still has plenty of capacity for a 105w chip running stock. More importantly, a 280mm would be a lot more quiet than a 360, since you'd have one less fan, and you won't have to spin it as fast. The best AIO on the market right now is the Arctic Liquid freezer II, but you might not be able to find one.
- The m.2 version of the WD Blue SSDs is a pretty mediocre NVME SSD, since it's a DRAM-less SSD. I would do a bit more research and find a faster NVME SSD, you probably won't have to pay that much more, if at all, for a NVME drive with DRAM.
- If you need to free up a bit of budget, you can always switch your SATA SSD for a Chinese one. Those Chinese SSDs are more than enough for storing games and other files on slightly faster storage, and they're quite cheap. I've had quite a few over the years, and they're pretty reliable. Since you're going to be putting your OS on the NVME drive, this might not be a poor idea.
- Remember that you can get gray-market Windows 10 Pro keys on eBay for around $5.
