I have one of these and the page says it is rated for 95W. https://www.quietpc.com/kozuti
What's the CPU? I'm wondering if it is worth considering running on power limit at the cost of a little clock at times.
Edit: apparently the cooler I linked is recommended for 65W and only 95W at max fan rpm. I don't know how loud that might get. I'm running mine on a 35W CPU.
https://linustechtips.com/topic/1189370-mini-itx-build/#findComment-13563861
That looks like a very sketchy cooler
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1189370-mini-itx-build/#findComment-13563868
4 minutes ago, boggy77 said:
aio? but your case has to fit at least a 240mm one. the 120mm ones are useless
The thought had crossed my mind too, but this was posted in air cooling subforum.
I've run a 120mm AIO on a 6700k (95W TDP) and with good airflow it is fine until it leaked some years down the line.
If you're space limited, what else would you do? It's that or a regular top-down blowing one.
https://linustechtips.com/topic/1189370-mini-itx-build/#findComment-13563873
Would a Thermolab/Cooltek LP53 fit the bill? TBH I think that in a space constrained chassis even a 120mm aio will do better than most low profile coolers. I'm running an H75 with a single fan and it vastly outperforms any air cooler that would fit in my system.
Daily Driver: Redmi Book Pro 14 - Core Ultra 7 155H | 32GB/1TB
Primary Desktop: NCase M1 - Ryzen 7 7800X3D/RX 6950XT | 32GB/2TB
Travel PC: Fractal Terra - Ryzen 7 5800X/RTX 3060 Ti | 16GB/1TB
I have too many computers. List here.
https://linustechtips.com/topic/1189370-mini-itx-build/#findComment-13563926
