Okay so bear with me
Mobo: asus prime b450m-a
It has 1 cpu fan, 2 chassis fan and 1 rgb connectors. Now i want to go for the cooler master Mb520 rgb case. (comes with 1 to 3 fan rgb controller). My cpu cooler is the CM master air ma410p rgb. And 3 case fans will be from the corsair ML120 3 fan/4 led strips/ rgb node/6 port controller kit.
Now, how would you suggest I connect these to the motherboard in order to control the lighting through corsair link/ aura sync?
https://linustechtips.com/topic/1188674-rgb-help/
It sounds like you don't have enough connectors but I'm not sure.
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
https://linustechtips.com/topic/1188674-rgb-help/#findComment-13559607
