Hey guys so I can't decide wich gpu should I pick, Im going to play assassins creed origins and odyssey, cod mw, cs go, lol, gtav. All of them at 1080p, 144hz, and ofc I like the better graphics but its not a thing that for example, if they are medium/high or high/ultra, that doesnt bother me, as long as they seem pretty or decent enough its all good. So my question is wich gpu should I get based on this, and wich will be more "future proof"? And im not thinking on playing at 4k.
Asus GeForce® GTX 1660 SUPER TUF Gaming X3 OC 6GB
or
MSI GeForce® RTX 2060 SUPER GAMING X 8G GD6
When I say bullet proof I mean is it worth it the extra 160 euros for the 2060 or by the time that I have to upgrade the 1660 the 2060 will prob have to be upgraded aswell?
And is the extra 160 euros worth it or the 1660 will get the job done?
Btw this is the build:
CPU - AMD Ryzen 5 3600
Motherboard -MSI X479 Gaming Plus
RAM - Team Group Kit 16GB (2 x 8GB) DDR4 3000MHz Night Hawk Black RGB CL16
GPU-  ???
HDD - Seagate Barracuda 2TB 7200rpm 256MB SATA III
SSD - Crucial MX500 1TB M.2 3D
PSU - Semi Modular Corsair TX 650M 80+ Gold
Thanks!!!
https://linustechtips.com/topic/1188625-gpu-help/
What country?
and what's your CPU?
The RX 5700 has the same performance as the 2060 super/2070 for less in germany looks like
This one's a bit more expensive but has one of the better coolers compared to the cheapest models.
https://de.pcpartpicker.com/product/NLPgXL/powercolor-radeon-rx-5700-8-gb-red-dragon-video-card-axrx-5700-8gbd6-3dhroc
https://linustechtips.com/topic/1188625-gpu-help/#findComment-13558536
I have a Ryzen 5 3600 with a 1660 super and I'm very pleased with it. I get 200 fps in Rainbow 6 and around 120 in Just Cause 3, CS GO gets like 300 (I'm not sure of the exact number because I don't play CS GO much.) You could go with 2060 and I'm sure it'd work better if you use like 4k and stuff but overall I love my 1660 super
https://linustechtips.com/topic/1188625-gpu-help/#findComment-13558542
7 minutes ago, Streetguru said:
What country?
Portugal, the cpu is a Ryzen 5 3600, here the RX 5700 is like 20 euros cheaper than a rtx 2060 super.
The problem with that rtx 5700 powercolor its that is sold out in the stores :/
Thanks!
https://linustechtips.com/topic/1188625-gpu-help/#findComment-13558553
yea in cs go i play all low settings because i prefer having performance so yea, sometimes i put it to max but meh.
Yea thats the thing im not going to use 4k so prob 1660 will do the job at 1080p 144hz.
Thanks!
https://linustechtips.com/topic/1188625-gpu-help/#findComment-13558558
Thanks!
I guess the part picker is off then, but this one says it ships may 7th
https://www.globaldata.pt/grafica-powercolor-radeon-rx-5700-red-dragon-8gb-gd6-rx57008gbd6-3dhr
https://linustechtips.com/topic/1188625-gpu-help/#findComment-13558565
The only thing is the problems with drives that amd radeon GPUs have : ( thats why i dont rly wanna get a amd one
https://linustechtips.com/topic/1188625-gpu-help/#findComment-13558625
The drivers are fine though? we're long past launch drivers for navi.
https://linustechtips.com/topic/1188625-gpu-help/#findComment-13558628
2 hours ago, JohndaKing said:
Oh thats true, ive never used a amd graphic so im kinda afraid ahah
Aside from ray tracing there's generally more features for AMD's hardware like GPU chill to keep power/noise down in single player games, or image sharpening to cheat out more fps.
Best to reinstall windows with any major hardware changes in any event.
https://linustechtips.com/topic/1188625-gpu-help/#findComment-13559122
I think im gonna save those extra 80 euros and buy more games ahah the GTX 1660 Will do the job, ty !
https://linustechtips.com/topic/1188625-gpu-help/#findComment-13559198
Should just get a VPN m8, for reasons...unless you mostly play multiplayer games
https://linustechtips.com/topic/1188625-gpu-help/#findComment-13559210
  • 4 months later...
I have discoverd that explainer.exe that comes with geforce update or geforce expérience act as some kind on malaware on pc. It blocks widows updates and many other fonction by eating all my 16gb ram and cpu.... Anyone else notices that in the control center (ctrl+alt+ del)??
https://linustechtips.com/topic/1188625-gpu-help/#findComment-14079988
