Yes, it's fine.  If you're worried about data loss, you should back up your data anyways.  Regardless of expectations, a drive failure can hit anybody at any time.  Just be aware that if you get a single drive and it fulfills all of your needs, chances are you're overpaying for storage: you get a little benefit from storing stuff on an SSD versus a hard disk, but not enough to justify the extra cost.  Outside of operating system files, only large games or projects really benefit from SSDs.  With pictures and documents, you're unlikely to really notice a difference unless you're an enthusiast.
#Muricaparrotgang
Folding@Home Stats | Current PC Loadout:
Small                        Bigger				Biggerer				Biggest
Fractal Design Focus G       NZXT H1				Lian LI O11 Dynamic XL			Fractal Design Meshify C
FX-8320                      Ryzen 3 3200G			Ryzen 5 3600				Ryzen 7 3700X
120mm AIO                    120mm AIO				Custom 280mm loop			Noctua NH-D15
A motherboard                ASRock B450 mobo			MSI x570 mobo				MSI x570 mobo
16gb DDR3                    16gb DDR4 @ 3200			16gb DDR4 @ 3200			16gb DDR4 @ 3600
a melange of HDDs/SSDs       WD 1tb m.2				WD 500gb m.2				WD 1tb m.2/2tb HDD
PNY GTX 1070 x2              GTX 1070				GTX 1070 FE				MSI RTX 2080 TI
some 650w PSU                650W SFX-L 80+ Gold		MSI RTX 2080 Super			EVGA SuperNova 750w 80+ GOLD
								Corsair RM850x 80+ GOLD
