2 minutes ago, boggy77 said:
what are the troubles with your current ram?
Long story short, I have a first generation Ryzen 5 1600x and I was told by my PC provider that it will take a bit of updating BIOS for it to work with my new sticks (maybe). I’ve been told to purchase a second generation Ryzen CPU but right now, I can’t afford to upgrade my RAM and CPU.
https://linustechtips.com/topic/1187278-need-help-for-new-ram/#findComment-13549379
5 minutes ago, boggy77 said:
any ddr4 ram should work with either 1600 or 2600 or 3600 cpus so I suggest trying it, it should work.
I have tried it, that’s the problem. It doesn’t boot up when all four sticks are in. I get the one beep then 2 short beeps indicating “no memory”
https://linustechtips.com/topic/1187278-need-help-for-new-ram/#findComment-13549462
try two sticks in slots 2 and 4. what cpu, motherboard and ram are we talking about?
https://linustechtips.com/topic/1187278-need-help-for-new-ram/#findComment-13549472
CPU: AMD Ryzen 5 1600x
GPU: GeForce GTX 1060 3GB
MOBO: ASUS ROG STRIX B350-F
STORAGE: 1TB HDD + 120GB SSD
PSU: 550W (not sure about specifics)
NEW RAM: HYPERX PREDATOR 4x4:
https://www.overclockers.co.uk/kingston-hyperx-predator-16gb-4x4gb-ddr4-pc4-25600c16-3200mhz-quad-channel-kit-hx432c16pb3k4-16-my-26k-ks.html
https://linustechtips.com/topic/1187278-need-help-for-new-ram/#findComment-13549511
