dme1737-i2c-0-2e
Adapter: SMBus PIIX4 adapter at 3010
5VSB:         +0.00 V  (min =  +4.50 V, max =  +5.50 V)  ALARM
Vcore:        +1.36 V  (min =  +0.00 V, max =  +2.99 V)
+3.3V:        +3.34 V  (min =  +2.97 V, max =  +3.63 V)
+5V:          +5.06 V  (min =  +4.50 V, max =  +5.50 V)
+12V:        +12.29 V  (min = +10.81 V, max = +13.19 V)
3VSB:         +3.37 V  (min =  +2.97 V, max =  +3.63 V)
Vbat:         +3.27 V  (min =  +2.70 V, max =  +3.30 V)
fan1:        1170 RPM  (min =    0 RPM)
fan2:         737 RPM  (min =    0 RPM)
fan4:           0 RPM  (min =    0 RPM)
temp1:        +45.3°C  (low  = -127.0°C, high = +127.0°C)
SIO Temp:     +45.6°C  (low  = -127.0°C, high = +127.0°C)
temp3:        +61.0°C  (low  = -127.0°C, high = +127.0°C)
cpu0_vid:    +1.088 V
https://linustechtips.com/topic/1187164-are-these-temps-okay/
1 minute ago, shadow_ray said:
Left click selection automatically copy text to your clipboard in putty.
Or you can use the built in sniping tool in windows.
dme1737-i2c-0-2e
cpu0_vid:    +1.088 V
https://linustechtips.com/topic/1187164-are-these-temps-okay/#findComment-13548724
