corrupt Help fixing ssd that got corrupted when power strip switch got hit accidentally
Solved by crazygamerfreak,
2 hours ago, Radium_Angel said:What you need, is a bootable LiveUSB (or LiveDVD) of a Linux distro. Linux Mint is most Windows like.
From there you can move data from the SSD to the HDD, and do a low-level reformat of the SSD. If it fails under Linux, then the hardware is bad and needs to be replaced.
ssd doesn't show up. i guess i need to replace the ssd only after buying it during christmas
