2 hours ago, L3gend2You said:
Hey guys, i never overclocked a cpu before so im hoping someone here can help me. I have a z390ud mobo, and a i7 9700k set to 3.8 standard. I would like to go to 4.8. I have a 360 aio so it could handle the overclock.Thank you guys
What brand is the motherboard?
My rig
Asus maximus z390
I9 9900k @ 5.2 Ghz 24/7 (5.4 Ghz benching)
Evga RTX 3090 ftx ultra
32GB Gskill trident z 3866 Mhz
1000 watt evga gold psu
All watercooled
https://linustechtips.com/topic/1186343-help-overclocking/#findComment-13542888
7 minutes ago, L3gend2You said:
Gigabyte
I dont know if gigabyte has it, but if it does enabling multicore enhancement would auto overclock it to 4.9 ghz on all cores. You would need to test thermals and stability after. Other than that every chip is different and would require some fine tuning to overclock it manually. It should be able to achieve 4.9 ghz on all core at stock or close to stock voltage though.
My rig
Asus maximus z390
All watercooled
https://linustechtips.com/topic/1186343-help-overclocking/#findComment-13542917
