Positioning of fans
priv4cy
Are the fan sizes the same? Or are the two on the front bigger?
Also, generally, you want an even intake and output fan ratio. I would make the two on the front intake, and the back and side output.
i think that they are all the same
Only one problem, it doesn't have big opening in the front it has little grills at the bottom but thats it its closed
In that case, make the two in the front intake, as well as the side. Your rear fan should stay as an output.
Okay thank you, also can you check the fans that i linked?
I'm not sure, it's not a brand I'm familiar with.
System specs? Budget?
From the look of the case, the front fan mounts probably wouldn't contribute to much airflow. You can probably get most of the same cooling with a side intake and a rear exhaust.
