Just bought my first custom build.
Any tweaks I should make or is it okay?
Thanks guys :)
  • Case(GAMDIAS TALOS M1A ARGB Gaming Case - Black)
  • Case Fans(Default Case Fan)
  • Processor(Intel® Core™ i9-9900K Processor (8x 3.60GHz/16MB L3 Cache))
  • Processor Cooling(iBUYPOWER 240mm Addressable RGB Liquid Cooling System - Black)
  • Memory(32GB [16GB x2] DDR4-3200MHz G.SKILL Memory - EZB)
  • Video Card(NVIDIA GeForce RTX 2080 Ti - 11GB GDDR6 - GIGABYTE GAMING OC (VR-Ready) - EZB)
  • Motherboard(GIGABYTE Z390 AORUS MASTER -- RGB, 802.11ac WiFi, USB 3.1 (5 Rear, 2 Front), AORUS Performance)
  • Power Supply(750 Watt - Seasonic FOCUS PLUS SSR-750FM - 80 PLUS Gold, Semi Modular)
  • Primary Hard Drive(500 GB Samsung 860 EVO SSD + 1 TB 7200RPM Hard Drive)
https://linustechtips.com/topic/1186086-first-build/
Is it a prebuilt from iBuyPower? Just wondering because of the AIO you listed.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1186086-first-build/#findComment-13540644
Thanks guys :)
how much did this cost? Also welcome to the forum!
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1186086-first-build/#findComment-13540667
a hefty 3 grand. I wanted a pc that would last for a while and not have to worry about improving graphics. The only adjustments I may make would be to add more storage but its enough for now. I really just wanted to know if it would preform fine and if the cooling is enough :)
https://linustechtips.com/topic/1186086-first-build/#findComment-13540723
@nicomaga98 Did you see the secret shopper series by Linus Tech Tips. He shows prebuilds from lots of companies including ibuypower and the conclusion was build your own pc if you can. This preforms better and cost $600 less.
Edit: Saving $500 the case is 100 dollar it just isn't available
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1186086-first-build/#findComment-13540733
I would have followed that, I watch his videos and keep track of what he says but i don't know how to build my own pc manually and have efficient cable management. Yes, I could watch more instructional videos, but I would rather choose the parts and have the company build it. Dont really want to risk anything. I could return my pc with no additional fees if I wanted to when it arrives. Im just worried about the cooling since I just chose default case fans
https://linustechtips.com/topic/1186086-first-build/#findComment-13540772
