I just got a new asus z170a to replace an msi one I was having problems with I have just put in my i7 7700k and my 1080ti and it won’t boot the cpu light goes on for a second the ram light goes on for about 10 seconds then they go off I have reset my cmos I can’t figure out what’s wrong
https://linustechtips.com/topic/1186072-new-motherboard-problems/
BIOS too old?
F@H
GPD Win 2
5 minutes ago, Unknown_origin said:
It won’t put anything to my display so I don’t know what it’s running
z170 was skylake (6th gen) and required a BIOS update to support kabylake (7th gen) CPUs.
Z270 was native 7th gen support.
you may need to find an older 6th generation cpu to update it, if it doesn't have some sort of bios flashback feature.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
It's most likely the case. 7th gen processors came along with 2xx chipsets, your older Z170 board would need a BIOS update to work with them.
F@H
GPD Win 2
I don’t have a 6th gen cpu
Also the guy I got it from said he ran an i7 7700k in it for a year so it’s not the bios
reseat everything, try again i guess
It had an i7 7700k in it for a year
"allegedly"
1 minute ago, Unknown_origin said:
could It be something to do with my old board doing something I had a msi z270 gaming pro carbon
maybe your old board wasn't what died
Nah it wouldn’t let me put windows onto my ssd it was having major issues
do you ahve different ram to try?
try one stick at a time?
Point is that maybe it's the RAM or CPU that have an issue and the motherboard was fine.
F@H
GPD Win 2
No it wasn’t definitely the motherboard it wouldn’t detect any of my drives on the right settings and when it was on legacy I couldn’t install window onto the ssd for some reason
