Not sure if this is the right place to go, but i need help. I am trying to set up my computer in a way to be able to run a program where the keyboard will type out a series of commands on a loop.
I am trying to have it do this:
up arrow, Shift + f10, down arrow, enter, enter, and then a 20 second delay before starting the cycle over again.
If anyone has any advice on a program that can do this or has the knowhow to create one, any help or advice is greatly appreciated.
https://linustechtips.com/topic/1185388-can-anyone-help-me/
You can use AutoHotKey to make a script that does this.
I would just recommend setting up some key that can 'stop' and 'start' this sequence of keystrokes.
https://linustechtips.com/topic/1185388-can-anyone-help-me/#findComment-13535234
  • 4 weeks later...
On 5/22/2020 at 4:30 AM, Priyansh_Singh said:
I use python you can use a module named pyautogui for this
This is very powerful and I ahve used it in the past for some fun lil automation scripts, and it does allow for a lot more powerful things to be done than what AHK offers, highly reccomended
https://linustechtips.com/topic/1185388-can-anyone-help-me/#findComment-13642171
  • 2 weeks later...
This AHK script does the following:
Waits for CTRL+Enter
When CTRL+Enter
> if not already running, sends the strokes sequence once, then repeats it every 20 seconds with a timer
> if already running, stops the timer
#NoEnv
#Persistent
#SingleInstance, Force
^Enter::
    if (!isRunning) {
        isRunning := 1
        GoSub, cycle
        SetTimer, cycle, 20000
    } else {
        isRunning := 0
        SetTimer, cycle, off
    Return
cycle:
    Send, {Up}+{F10}{Down}{Enter}{Enter}
    Return
To change the trigger hotkey, replace line 5 at your convenience:
useful resources here
Let me know if it does the trick
Edited by JuliaAlphaDeltaEcho
Timer was set at 2 seconds instead of 20
https://linustechtips.com/topic/1185388-can-anyone-help-me/#findComment-13696931
