i was looking at the Raystorm kit (http://www.frozencpu.com/products/20835/ex-wat-263/XSPC_Raystorm_750_AX240_Universal_CPU_Water_Cooling_Kit_New_Rev_4_Pump_Included_w_Free_Dead-Water.html)
My processor is an 8350 @ 5GHz and 1.62 volts.
GPU is a GTX 760 but i have a kraken g10 with an h90 cooling it
i plan on getting a mobo block for my crosshair v formula z
is this kit enough too keep my system cool? i plan on adding an extra rad in addition to the one in the kit.
im currently using a h100i and nf-f12 in push pull. my temps are around 75C on load and 22C idle.
will i get a big improvement? will the temps be below 50ish?
Thanks.
PS not looking to spend a hundreds, 200 max for the kit and this looked really good.
CPU AMD FX 8350 @5GHz. Motherboard Asus Crosshair V Formula Z. RAM 8GB G.Skill Sniper. GPU Reference Sapphire Radeon R9 290X. Case Fractal Design Define XL R2. Storage Seagate Barracuda 1TB HDD and 120GB Kingston HyperX 3K. PSU XFX 850BEFX Pro 850W 80+ Gold. Cooler XSPC RayStorm
https://linustechtips.com/topic/118503-best-custom-water-loop-kit/
To be honest I am not that sure but I don't think it would make a huge improvement. It will be an improvement but I highly doubt you will get to 50C though if you are running at 5GHz. My guess is at best, you will knock 10C off your current temps. Again I am no expert so maybe wait for other people to answer.
I think there is a thread called 5GHz club. Look for other members who are up around those speeds and ask them directly.
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
you most likely will not see temps below 50C
System: 5930K, MSI X99 SLI PLUS, GTX 780Ti (SLI),  840 EVO, Fractal R4 (Full Custom Loop)  (IP)
Media Server/Perm Folder: i3 4130, CX500, 4 X WD Red 1TB, 60GB Adata SSD for boot, Node 304, ASrock Z87-E ITX, 8GB Kingston Value Ram
theres no point in setting up a custom loop for such a low end card you already have a g10 on it thats more then fine
Specs
If you already have the G10 on your GPU and the H100 then don't bother, you might see a 2 or 3 degree reduction on load and that is about it. This kit would be good for doing your CPU if you didn't have a AiO already and even better if you planned to add your GPU and an extra rad. As a CPU cooler alone, stick with the H100
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
