Hi all!
Could someone build me a pc? I would be using this computer to play Minecraft w/optifine and web & Java development. My budget should be preferably below or around $700. Not including OS.
Processor: AMD Ryzen please!
Mobo: I've had trouble finding a matx case that looks good, so if you can suggest a good case, I'm fine with matx
Memory: 2x8gb DDR4-3200
Storage: I've got a 500gb SATA SSD at home, but I'm looking for a fast cheap m.2. Maybe P2?
Video Card: at least one HDMI and one display port. Please no vga! All I need is one that can get good fps on Minecraft. Maybe the Gigabyte GeForce GTX 1660 SUPER 6 GB OC? Or something cheaper.
Case: Please make it look good! Good airflow, comes with fans, maybe rgb fans? USB 3! Tempered glass.
Power supply: I really don't know lol
Thanks,
Coding
https://linustechtips.com/topic/1184893-help-making-a-good-build/
What region are you in and what resolution are you going to use to play games on?
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
