I’ve got an rtx 2080 that I have been trying to watercool using an ekb waterblock. It wasn’t working on boot so I took a look and found that a silver piece has broken off. Don’t know what they’re called but it’s stubby looking in a cylinder shape with eay52 270 and 16v on the top. Is this fixable or am I screwed plz help I can’t afford to buy another one.
https://linustechtips.com/topic/1184192-someone-plz-help/
check with ek support and get a picture
https://linustechtips.com/topic/1184192-someone-plz-help/#findComment-13526552
A photo will definitely help but what you are describing sounds like a sealed/polymer capacitor.
https://linustechtips.com/topic/1184192-someone-plz-help/#findComment-13526570
