HI Guys,
 I am looking to start my first build and I have already chosen my SSD and CPU ect. But i'm worried that I might be going overboard with certain things like the power supply, ect. I'm looking for a high spec gaming PC, that will also be fit for game development. Below is a list of the components I have chosen, and advice Is welcome Thanks.
Mother Board: MSI B450 GAMING PLUS MAX Motherboard ATX, AM4, DDR4, LAN, USB 3.2 Gen2, M.2, MYSTIC Light Sync, HDMI, DVI-D, AMD RYZEN 1st, 2nd and 3rd Gen Ready
SSD:Samsung 860 EVO 1 TB SATA 2.5 Inch Internal Solid State Drive (SSD) (MZ-76E1T0)
CPU:AMD Ryzen 5 3600 Processor (6C/12T, 35MB Cache, 4.2 GHz Max Boost)
Tower:Corsair iCUE 220T RGB Airflow, Tempered Glass Mid-Tower ATX Smart Gaming Case, Black
Graphics Card: MSI Nvidia GeForce GTX 1660Ti Gaming X 6G Graphics Card 6 GB GDDR6, 1875 Hz, RGB Mystic Light, 3x DisplayPort, HDMI, Dual Fan Cooling System
Power Supply: Corsair CP-9020070-UK Professional Platinum Series 1200 W ATX/EPS Fully Modular Power Supply Unit
Ram: Corsair Vengeance RGB PRO 32 GB (2 x 16 GB) DDR4 3200 MHz C16 XMP 2.0 Enthusiast RGB LED Illuminated Memory Kit - Black
Rear Fan:Corsair iCUE SP120 RGB PRO, RGB LED, Low-Noise, High Airflow, Case Cooling Fan (Single Pack), 120 mm
Top Fans:Corsair Hydro 100i RGB Platinum, Hydro Series, 240 mm Radiator (Dual ML PRO 120 mm RGB PWM Fans, Advanced RGB Lighting and Fan Control with Software) Liquid CPU Cooler Black
Again any suggestions and help welcome
Thanks Guys.
https://linustechtips.com/topic/1184114-my-first-build/
That PSU is definitely overboard by an AU. 500w PSU should be enough for that and unless electricity is really expensive or limited (e.g. powered by diesel generator somewhere nearby) you dont need 80+ Platinum rating, just Bronze or Gold will be enough (though 80+ white is not recommended, Bronze ones are cheap enough)
Overkill AIO for CPU unless you're going after looks
220T's airflow turns out to not be as good as a clean mesh front case
1660Ti gets beaten by 1660S in price to performance, though with the money saved on the PSU you might as well get a 2060.
Desktop benching:
https://linustechtips.com/topic/1184114-my-first-build/#findComment-13526048
I think you should pick the MSI B450 Tomahawk instead.
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
https://linustechtips.com/topic/1184114-my-first-build/#findComment-13526104
11 hours ago, merco said:
What are you using for this? I imagine game development can have wildly different minimum specs depending on how good the graphics of the game are, just like gaming itself right?
It will be for playing games and developing them using unity.
https://linustechtips.com/topic/1184114-my-first-build/#findComment-13527411
4 minutes ago, tgzy94 said:
Any reason for this. Is that mother board basic?
The motherboard I picked is better.
Main Rig :
Laptop :
https://linustechtips.com/topic/1184114-my-first-build/#findComment-13527417
For my graphics card I don’t mind paying a ridiculous money as it’s worth it.
which cpu you recommend i9 or i7?
the 220T has the fans to the front of the case with a mesh cover, with 3 extra fans in the back?
money isn’t really an object. But if I could get it all for 1500-2K would be great
thanks for everyone’s help.
https://linustechtips.com/topic/1184114-my-first-build/#findComment-13527422
Straight to the point huh? :D
I think it has better VRMs which is great if you're trying to overclock, but I also saw yesterday that it is sold out in the US.
The gaming plus is a bit cheaper but honestly fine for normal use of a 3600.
https://linustechtips.com/topic/1184114-my-first-build/#findComment-13527426
Yeah, to be fair, this is just a 3600, not the 3900x. You don't really need the latest and greatest. So, should be fine.
Main Rig :
Laptop :
https://linustechtips.com/topic/1184114-my-first-build/#findComment-13527440
1500-2000 should get you far better than the spec that you listed. Is this in USD?
Main Rig :
Laptop :
https://linustechtips.com/topic/1184114-my-first-build/#findComment-13527443
57 minutes ago, tgzy94 said:
Nope. British Pound :)
I'd say keep the other stuff but bump up the CPU to a 3700X and the GPU to an RTX 2060 or an RX 5700XT.
Main Rig :
Laptop :
https://linustechtips.com/topic/1184114-my-first-build/#findComment-13527616
It looked like you wanted RGB so I left the RAM in there (without RGB would have been like 30 less)
Same reason I didn't choose a case or cooler that's kind of a matter of looks, so it's subjective.
This would be a fantastic build imo, that could handle everything you throw at it. If you wanna develop with unity you can make use of more cores and better GPU for sure, especially if you want to make graphically demanding games.
This would be a more budget oriented rig, but also a very capable PC that I would quite honestly be more than happy with:
https://linustechtips.com/topic/1184114-my-first-build/#findComment-13528024
Worth it for a slower card
neither, Ryzen's fine
Exactly, you can do better with say, a Meshify C or NR600 after adding the same fans to them
Desktop benching:
https://linustechtips.com/topic/1184114-my-first-build/#findComment-13528601
