Since i installed a new cpu heatsink, my gpu has been idling at temperatures of 49 (c) degrees and when i play a low demand game (pc Building Simulater) I get 89 (c) degrees. i turned the settings all to low cause i didnt want my gpu to overheat. Plz help idk what to do. i scanned my pc for miners or viruses many times (full scans) and i found nothing. my cpu also has higher temps not as bad tho.
Please help me out and donate to my go fund me to help get parts for a gaming pc. Any amount is useful. Thanks! (dm for link)
https://linustechtips.com/topic/1183692-help-my-gpu-is-overheating/
Just now, 5x5 said:
which cooler model more specifically. Try increasing the GPU fan speed with Radeon settings or MSI afterburner
radeon rx 580 4 Gb its at max fan speed at all times
Your case have good air flow ?
CPU - I9 10900 | CPU Cooler - Corsair Hydro Series H100x AIO | Motherboard -  Aorus B460 PRO AC | RAM -G.SKILL Ripjaw V series 4x8GB 2666MHZ | Graphics Card - Gigabyte RTX 3070  | Power Supply - Cooler Master 650w  | Storage -  Working on a new Spicy
Operating System - Windows 10 Pro
idk that is what i was thinking. should i take pics
would help us a bit
3 minutes ago, hiimnewplsbenice said:
just checked every second my gpu fan stops spinning then starts then stops over and over.
how do i fix?
how do i fix?
nvm about everything guys. just remembered my rx 5700 comes in the mail tommorow. sorry I actually feel bad for making u guys go through the trouble of helping me then i just say nvm. Im truly sorry.
how do i fix?
Uninstall all broken monitoring and overclocking software(afterburner etc). Then re-install gpu-drivers with the clean install option.
thx
