Help!!! I'm putting together my first PC and my graphics card won't click into my PCIE slot. There seems to be this weird nub attached to the PCB that isn't in any of the product photos that is interfering with it fitting into the slot. What is this, and how do I remove it?? Thank you in advance for any help with this.
https://linustechtips.com/topic/1183443-help/
It's left over from the factory, you can snap it off. I'd use some pliers or something.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1183443-help/#findComment-13521813
