Hello , this is my first time posting here so please tell me if something is wrong or any info is missing.
I'm having drivers issues with my XFX RX 560 ,  i was updating to Adrenaline 20.x (Recommended option) and once it finished the install , made a restart like the drivers required, i saw bios options, post , everything was good but it just start windows like the image, in user selection, in desktop screen, everywhere, i thought it was the new driver so i tried a downgrade using DDU and getting the one that i was using all this time ( which was, in a surprising way, catalyst amd drivers) but now it still shows the screen like the picture. i've checking many solutions but none of those works. Ask for a friend computer to use there but still not working, tried other display like msi or asus monitor, in intel or amd systems, almost every driver from crimson or adrenaline , even 20.4.2 which was release a couple days ago.
Does this have solution or it is just time to throw it away and get an upgrade?.
My system is : Ryzen 3 3200g with 16gb ddr4 ram kingston, 120gb kingston and evga 500w 80 plus white.
EDIT : 04/25, still cant find a solution.
https://linustechtips.com/topic/1183144-rx-560-display-with-dead-pixels/
I've had a similar problem with a video card, and it was a bad memory chip. An RX 560 is pretty new though so unless there was some sort of electrical debacle that seems unlikely.
Try getting in to safe mode in Windows and see if it still has that patterning in the display.
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
Thanks for your reply man, i appreciate it.
I just got into safe mode like you said and i don't have that issue. Only in normal mode. That's good right?.
Even in device manager it says that i'm using a rx 560 but after restart to get into normal use it shows up again those black pixels.
This is a common sign of memory corruption, usually from overclocking too much. It could also be bad memory on the card. How old is it?
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
1 year and half , i had a fx 6300 before but i'm very careful with this things and never made OC or play something that makes my gpu temperatures hot.
Edit: By playing something i mean never had ultra details lol. I know it sounds depressing
  • 2 weeks later...
