so, whenever i play bf3, within 15-20 minutes of playing my whole computer freezes and makes a sound looping "brrrrrrrrr" sound, and i can't do anything apart from a hard reset.
anyone know the problem or solutions here?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/118300-bf3-freezes-help/
Specs, drivers, settings. :)
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/118300-bf3-freezes-help/#findComment-1578152
Have you clocked GPU?
nope, it's all on stock
Old Rig
https://linustechtips.com/topic/118300-bf3-freezes-help/#findComment-1583020
Have you tried reinstalling drivers or using older ones? Are temps ok? Do any other demanding games cause same issue or just bf3?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/118300-bf3-freezes-help/#findComment-1583137
i've got the latest drivers from nvidia, the temps are ok, the gpu runs at 40-50 degrees and cpu at 45 degrees. I've had the same issue with other games such as far cry 3 and titanfall beta
Old Rig
https://linustechtips.com/topic/118300-bf3-freezes-help/#findComment-1583167
Well... I think your GPU might be faulty. I'm not entirely sure though. If you can test with another card that would tell if its broken or not.
https://linustechtips.com/topic/118300-bf3-freezes-help/#findComment-1583312
