1 minute ago, 0gK4M1 said:
Does anyone know if it's possible to create a dual threadripper system?
what do you mean? like 2 CPU's on one motherboard or two motherboards with 1 CPU in the same case?
Only EPYC supports 2 CPUs per board.
2 minutes ago, 0gK4M1 said:
Like two threadrippers on one motherboard
nope, that's not gonna happen. Like @Streetguru said, only AMD's Epyc line of CPU's support dual CPU configs.
