will this CPU cooler fit?
klapstok
Hi guys,
i've had my pc for a while and I didn't install a CPU cooler from the start.
So yeah I've been running an AMD stock CPU cooler on my Ryzen 5 3600, which is okay, but loud.
Now i'd like to install the Coolermaster Hyper 212X, but I have no clue if it'll fit or not. Anyone that can help?
(atleast I THINK its the CPU cooler that's making a loud noise!)
build:
CPU: Ryzen 5 3600
CPU cooler: AMD stock cooler (that comes with the CPU)
GPU: MSI Radeon RX 5700 XT gaming X
MotherBoard: MSI B450-A PRO MAX
RAM: Corsair Vengeance LP
PSU: Corsair TX-M Series TX650M V2
CASE: coolermaster masterbox  MB520 RGB
What case are you using? Have you tried lowering fan speeds?
Do you already have the cooler? Newer stock of the Hyper 212X should have AM4 mounting hardware.
hey,
I haven't bought it yet
My case is coolermaster masterbox  MB520 RGB
How do I lower the fan speeds? 🙂 i'm a big noob..
Also, wouldn't lowering fan speeds affect my gaming?
Now while browsing the fanspeed is 980 RPM. no idea what that'll mean but its some extra info :)
If fans are connected to your motherboard, you can control them through the bios. If the fan isn't spinning very quickly, you can also stop the fan with your hand by pressing down on the center hub and see if that fan is the source of noise.
Lower temps can mean better boost clocks but it's not much past just having sufficient cooling. If temps are fine, it's not a bad idea to run lower fan speeds for less noise. What are temps with a synthetic load? I personally use OCCT. https://www.ocbase.com/
If you don't already have the Hyper 212X, you're probably better off getting a different cooler. It's a bit of an older cooler and there are likely better alternatives for the price. Where are you shopping / located? Budget?
Alright, I downloaded OCCT and when i go to 'FAN' i see CPU fan is at 1600, the other 3 SYS fans are at 800-1000. What would you recommend? I am from Belgium and I'll probably purchase it from amazon.nl. Price range about 35 euro.
11 minutes ago, boggy77 said:
i'd go for this instead. I know it's huge, but it's much much better than the hyper212
Thanks! I'll check it out. Will it fit?
Yes, it fits and would be a better option.
There are also a few more shop options listed on tweakers.net https://tweakers.net/pricewatch/887311/gelid-solutions-phantom.html
I have another quick question: I am just browsing and i notice on the OCCT that GPU temp is at 60° Celcius. Isn't that a bit high? Or shouldn't I worry about it?
Under load or idle? Idle its hot, if fans are still running. Under load its very cool (GPUs can go to 75C+ under even gaming loads without issues).
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
It's a bit high but not abnormal if your case doesn't have great airflow since the graphics card fans stop until 60c.
yeah fans werent running, they started running when above 60, then it cooled down to 45. so i guess its all good
Yeah, its fine. You can adjust those fan curves if you feel like starting temp should be lower.
good to know, but I'll trust the system. I don't want to mess things up :D
