Hi,
I've set up an Intel Unraid System (6700k, Z170 board, 16GB RAM, RX580 GPU).
The problem i'm having is the Windows 10 VM will only be able to output video to a specific output display.
I wanted to set it up as a VR rig in my living room, and before this, it had Windows 10 directly installed on the SSD's and worked with out main television.
After installing unraid, setting the Intel Onboard GPU for unraid and the RX580 to the VM, it refuses to give any display out, unless i plug it into a spare tv in another room, which enables the display output and shows up.
Is there something in Unraid to tell it to output a signal regardless of what it's plugged into, or would this be a TV issue (keep in mind, it worked perfectly before, with the same GPU, Same TV, Same cable, Same port).
https://linustechtips.com/topic/1182368-unraid-gpu-output-issues/
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
19 hours ago, Electronics Wizardy said:
you can get dummy outputs that make the gpu think there is always something plugged into them.
The problem isn't that it won't output video, it works on a different display.
It just won't output any video to this specific TV if the GPU is in the VM. It works on a dedicated machine
