3 minutes ago, TomeR12 said:
so i have 2 screen 60hz and i have rtx 2060super with amd rayzen 3600 i know 60hz is max fps can run is 60 but anyway i play and my fps low my max fps maybe 130 and i have drops so what can i do?
What is the lower bound in FPS are you getting again? That was sort of left out. Either way, have you tried disabling one of your monitors while gaming? That's what I've been doing with my system as the second monitor is basically useless to me in game.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1182246-low-fps-two-monitors/#findComment-13513483
Several questions: What game, what FPS do you expect, what FPS are you getting, why can't you write properly?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1182246-low-fps-two-monitors/#findComment-13513523
i have sometimes even 3fps  I usually didn't have that low, I had a constant 160 i try to disable one monitor and its help but i had 200fps not constant and when i was with one monitor i had 500fps
https://linustechtips.com/topic/1182246-low-fps-two-monitors/#findComment-13513542
fortnite, i know fps with 2 monitors is low but i think less 165 constant, i get 5-130, english not my main language
https://linustechtips.com/topic/1182246-low-fps-two-monitors/#findComment-13513550
