Alright been watching ltt for a very long time and this is my first post on the forum and it isn't even about computers it does however have to do with air-cooling so I thought to give it a shot.
So I have a 3d printer in my bedroom with an obnoxiously loud cooling fan on the power supply so I decided I want to change it. It is a 60x15mm fan and was hoping to swap it out with my noctua 60x25mm fan but that is too big andthey don't make a 60x15mm fan at all. Does anyone know of a good brand that makes a decently quiet 60x15mm 5v PC case fan? I can find this size and voltage quiet easily on Amazon but I don't trust chinesium for reliability or quietness.
https://linustechtips.com/topic/1181881-need-specific-size-fan-help/
8 hours ago, Rainbow Dash said:
I think most fans are manufactured in China nowadays, there is one problem though; 60mm fans are not common for pc fans, and the best I could find is Deepcool XFan 60 which is 60x15mm.
Thanks but unfortunately that's 12v and won't work. While yes most are made in China I wanted one from a name brand at least. Thanks anyways though.
