Hey guys! I've been doing a bit of research on replacing a panel, and came across the famous video of Linus being a hero to his monitor(Alex's monitor);
Long story short, a friend's screen (I swear, not mine)  fell off, the panel got a direct hit, and has a good crack,
I have done researches on the panel, (Predator XB241H, 60,96 cm (24"), 144Hz, G-SYNC, TN - DP, HDMI)
But I can't seem to find a straight answer on what panel would fit/be compatible...
I've wondered if i needed a very specific panel, or if "any" so long they're the same size, would simply fit and work out...
Could someone run me through how that works, in the most detailed way?
If someone has any link to panels that would work, please mention them
Thanks for your answers and time!
https://linustechtips.com/topic/1181657-panel-replacement-predator-24-tn/
you would have to find the panel that is made for that specific model of monitor.  If your willing to take the panel off, that would be the best as they generally have a serial number on the back of them that you are able to then look up and try and find it
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
