hi i am trying to give my java sever 4g of my ram i have 8g of ram
but i am getting this error
Invalid initial heap size: -Xms4096M
The specified size exceeds the maximum representable size.
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
Press any key to continue . . .
the code i am using for start up is @echo off
java -Xms4096M -Xmx8192M -jar server.jar
PAUSE
i have tried to Make the xms and xmx the same but still the same error
https://linustechtips.com/topic/1181451-need-help/
You’re trying to reduce ram from 8gb to 4gb?  Why?
https://linustechtips.com/topic/1181451-need-help/#findComment-13507887
1 minute ago, DJWOLFF101 said:
what do u mean
He means the tread was moved from “general discussion” to “troubleshooting” because you’re trying to fix a specific problem.  Makes sense to me though regardless it is best  not to question the mods for they wield the mighty banhammer.  This is a forum rather than a social media thing like twitter or reddit.  Older school of social media.  It has actual live people moving things around, enforcing rules, and doing what amounts to civil service work.  It’s much better imho.  Newer style social media sites were designed for scale not quality.
https://linustechtips.com/topic/1181451-need-help/#findComment-13508026
