My AMD Wraith Prism that came with my R7 has a cord that won’t fit into my ASRock B450M Steel Legend, and I was wondering if this might be a deficiency, or my own stupidity, or a compatibility issue. Thanks for your feedback.
It is the NOT the RGB USB cord. It is the 4 pin connector that goes into the CPU_FAN1.
In the Installation Guide for my Mobo, as well as the AMD Installation Instructions, it shows a cord that doesn’t 100% resemble the cord I have. It seems like from both guides that I got 2 RGB cords.
Maybe a lost cord? How many cords does the AMD WRAITH PRISM ship with?
Edited by Spectra1duke387
https://linustechtips.com/topic/1180771-amd-wraith-prism-problems/
The prism should have a CPU fan header to power the fan itself, and an optional USB2 or RGB header to power the lighting, all of which are headers that should be present on the steel legend. Take a look at your board manual to find the header that your chord of choice (either USB2 or RGB) plugs into.
